Solved Chat issue after installation
Dabo
HI!
I installed the plugin on WordPress, I put the link inside the plugin and everything seems to work.
but it only works when I'm logged into WordPress, while after logging out the icon is not visible.
I browse the site with other computers and the icon is not visible.
I go back into the wordpress backend and the icon appears and everything works.
help!
tnx
Hi, I wonder what is the plugin version that you installed?
Are there other plugins installed in your Wordpress that may interfere?
Did you configure the live chat in all your web pages?
What is the website url?
In the chat configuration in the PBX are you using https or just www?
Thank you.
can you remove the last / from the url?
- the version: 10.0.10
- i configure the live chat in all my pages
- url: https://metagroup.srl/
- maybe one plugin interfere, i try
Can you show me the Chat configuration from the PBX?
i found is "wp rocket" that block it.
i disable it.... or maybe you know how i should change in wp rocket configuration?
This is not something related with 3CX Chat as this s a caching plugin. Since this wp plugin was interfere with the 3CX plugin you will need to check the documentation of this plugin for further clarification.
ok tnx form help!
only one last question: i try to send me a message with another pc and all seems work...
but where are the conversations stored? on 3cx app? or even in wordpress?
The chat are stored in the PBX, under Dashboard<<Reporting<<Chat logs
Reactions: Dabo
Finatra.us
