Choose how logs are generated
leyanu
Platinum Partner
Hello Guys,
What is the difference here.
  1. Single file for all calls
  2. Separate files for each call
  3. 3CX CDR service is server / Passive Socket
  4. 3CX CDR service is client / Active Socket
The option I selected (Separate files for each call) shows me data the way I see it in the image and even for calls where I get a switched off notification. It comes out as an answered call
Hello Guys,
I would prefer that it be grouped as an unanswered call once the customer did not pick that call. I use a GoIP gateway in case that should be a consideration.
florentrobineau
