Choose Your Outbound Caller ID in 3CX V20 Update 10
KyriacosS_3CX
Staff member
Select an assigned DID before each external call, with no extra outbound rules to maintain.​
Calling from the right business number matters when users represent multiple brands, offices or services. With V20 Update 10, Admins can let users choose which of their assigned DIDs to use before placing an external call. This means one...
This is definitely a step in the right direction, however the majority of use cases for our customers will not be a user's assigned DID but a group/queue/DR DID. It could even be a number that is not on the SIP Trunk at all.
Will this ever be implemented to allow numbers outside of assigned user DID's?
I cant see why this wouldnt be implemented in the future, it seems logical to.
It would be really great too, if the DID names could be taken across for easier identification (Again, suspect this will come)
There's significant conversation about this in the other (alpha) thread, but since (last I checked) you can already chose a DID for SMS (when starting a new convo) that's assigned to a queue you are a member of, I suspect that same logic will come here.
It's unclear to me how the bypass outbound rules works. If your outbound rules include your normalisation, ie if you have multiple providers that have different requirements around CLD presentation, does selecting a specific route then pass the call to the trunk without any normalisation?
To use another outbound caller ID it must be assigned to the extension, this can not be bypassed. Re calling using a queue DID if the person is part of that queue and the DID is assigned to the queue is something we will look at but its not something quick to do.
In our customer base using the DID of a queue is the more common use-case (agent has multiple hotlines). The OutboundDID by user is also used, so still a good feature.
Would be great to see a checkbox in a queue, "Allow agents to set DID of queue" to control this. Someday in Update 11, V21... whatever
Best regards
The caller and called numbers would be passed to the trunk associated with the DID as seen in the dialer.
You can use the settings found in the Trunk config Options section (E164 conversion, caller ID reformatting ) to ensure numbers are consistent across Trunks.
Best regards
For now, Update 10 is still an Alpha release and shouldn’t be deployed in a full production environment.
But I’m not telling you anything new here.
However, if Update 10 had been available for deployment in production, making it possible to select the Caller ID directly in the applications, and users needed to select the Caller ID from the application rather than through an outbound rule prefix that forces a specific Caller ID, I would duplicate the DID in the SIP trunk, add a prefix to it, and assign it individually to the users who need it.
For example, if the DID is 5147770000 and the extension of the user who needs the Caller ID selection feature is 2345, I would add the same DID again with the extension as a prefix:
2345.5147770000
I would then add two Outbound Caller ID Reformat configurations.
The first one would have priority and would handle the Caller ID without any customization:
Source Pattern: (5147770000)
Replace Pattern: \1
The second one would be used to clean up the prefix:
Source Pattern: (....).(.*)
Replace Pattern: \2
I’d simply explain to the users that they should ignore the prefix, meaning the extension followed by a dot, followed by the Caller ID.
Obviously, this takes longer to configure than simply enabling an option in a Queue, but in a situation where that option isn’t available, I believe there are several workarounds available to achieve an equivalent result.
2345.5147770000
Replace Pattern: \1
Replace Pattern: \2
Nice trick, but when I think about 30-40 Agents, having around 80-90 Queues... :oops:
I would put that aside for later as dirty workaround, hoping for a clean solution.
LOL, I didn’t say my solution was better than your idea It’s just a basic workaround. But it’s still doable. You eat an elephant one bite at a time. xD
Well, I just hope there isn’t too much agent turnover in those queues:p
Would the option to choose outbound caller ID via Windows softphone also work when the softphone is set to CTI (to desk or smartphone)? In our situation, our customers also have 5+ single DID's for 5+ companies, staff do not have own DID's, so letting us choose another DID would be prefererd, or the workarround suggestions of above posters ofcourse...
you can only choose DIDs that are assigned to extension at the moment and it does work with CTI
Reactions: martijn189nl
I have updated to the latest V10 release and enabled this setting in the Options as per the blog. In the web app I can see the drop-down asking me to select an outbound ID from the 2 I have allocated to an extension. However when I test this on the iOS app I don't see the drop-down selector as is shown in the blog.
Am I missing a step to get this enabled in the iOS app? I've uninstalled the app and re-installed/re-provisioned etc.
Only available in beta atm see latest news post
Reactions: KyriacosS_3CX
OK, assuming this means the beta version of the iOS app as well as the PBX then and there's no way to install the Beta iOS app as not in the AppStore?
ARKC
