- Joined
- Sep 14, 2020
- Messages
- 47
- Reaction score
- 2
Hi all, I am totally new to 3CX but so excited about the possibilities it provides, finally my team and I will be able to afford a proper PBX system.
First hurdle though is to choose the right hardware to run 3CX on.
Expected usage: Max 2 simultaneous calls from outside from time to time and 3 simultaneous calls within the office at most. Voicemail will be activated, and 4 office users will be running the mobile app when they are not at their desk. A Fanvil video doorphone will be a part of the system so from time to time the doorphone may trigger a video stream between the doorphone to the reception deskphone and the mobile apps in the hunt group.
Here are my questions:
1. For the above usage, is either a Raspberry Pi 4 or the existing Synology 720+ NAS that we already have sufficient? It's still under the simultaneous 8 calls limit and the video streams I assume don't tax the CPU as they just stream from device to device?
2. This page on 3CX site shows the steps for installing 3CX on a Raspberry Pi 4, but on the hardware requirement page, it shows Raspberry Pi 3B+ is supported only. Is Raspberry Pi 4 actually supported?
3. My Synology 720+ NAS has a Quad Core Intel Celeron J4125 GeminiLake CPU with 10GB DDR RAM. I have allocated 1 core and 2GB of RAM to the Debian Linux that I obtained from 3CX and have successfully installed the OS using Synology's Virtual Machine Manager which is VMware vSphere certified. I have even configured the 3CX Management Console already, but what are some of the tests I could perform to make sure 3CX is running properly on this VM?
4. Which device of the two above is more suited to be used as the main hardware running 3CX?
5. Which of the two above is more suited to be used as failover device where automated backup and restore is running?
Your help will be much appreciated.
