Solved Chrome extensions slows down chrome while active call
Sebastian Schubert
Hi there,
as a linux user with no native client, i use the chrome extension almost like it came out and never had a real issue.
Since about 2 month i experience very poor performance within chrome while i'm on an call in the webclient.
Scrolling in a tab or even selecting a tab is insane slow ...
Using any other application at the same time is ok, just chrome is affected.
OS is Fedora32/x86_64, Chrome is 86.0.4240.75
I do not have this issue on my Mac with MacOS Catalina and the most recent Chrome :-/
Hi Sebastian,
We do not test or support the client on Linux specifically, but the main idea is that is should work on all platforms if its written for chrome.
You might wanna try a different Linux disto for your desktop and compare, but when I gave it a quick go, Fedora 32 did not perform well on my test VM (choppy audio across the board). The extension and Chrome did work fine though, choppy audio aside
looks like it's an fedora issue - thanks for your support anyway! :-)
Reactions: JohnS_3CX
You're welcome!
Roman Mazur
