CIDR - block everything
expat1001
New Customer
Excuse me if this has been posted - I cannot find out how to to it including Google searches. I want to change phone authentication to whitelist, and block everything else. What CIDR notation should I use for the blacklist?
Thank you.
Thanks but is there a problem blocking everything on 3CX? I'd prefer that for organizational reasons. The info on that page is out of date. it does not use CIDR to set the IP range. I still don't know how to block everything that way.
The place where you add IPs to the Blacklist/whitelist is located in the Dashboard --> IP Blacklist.
The interface should be pretty self-explanatory, it even calculates the IP ranges for you:
If you don't fully understand this, it may be a good idea to ask a 3CX Partner for help.
Now whether or not you can block everything in 3CX except the IPs you want, theoretically you can, but you need to remember one thing:
  • 3CX is a PBX, not a Firewall
What I mean with this is, you could, but don't, do it on your Firewall.
Thanks but the only thing I am asking is the IP range and / mask to block everything.
florentrobineau
