- Joined
- Nov 12, 2021
- Messages
- 4
- Reaction score
- 2
Thanks for that, I particularly need the Cisco 7941 template though if you have it.Here you are
Just go to 3cx console -> settings -> templates -> choose any availble -> click copy -> replace text and save
FYI, the templates are still on the server if you browse to the directory where templates are kept. That is where I got my copy.Thanks for that, I particularly need the Cisco 7941 template though if you have it.
When do you anticipate this change will be taking place?You are best off configuring these phones manually or using the tools that came with the phones. We are going to update our guides how to do this.
Using the templates is just buying a few more months time because eventually local lan provisiong is going away. Local lan provisioning relies on HTTP and its not secure.
So if you want to use these old phones provision them manually independently from 3CX. If you use a strong password, you should be fine....
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
