Cisco Port-Forwarding Command
NewbieBryan
Forum User
Are there any Cisco commands to do port-forwarding using range?
I'm trying to do port-forwarding for the udp ports 9000-10999.
I had previously used a one command for each port, but it doesn't look healthy in this case.
Can someone let me know what can be done?
Thank you
Hi NewbieBryan,
Are you able to tell us what device you have and firmware version?
fngl
