clear call logs - does not work as I imagine it should work
PhilK
Forum User
We have an agreement for data protection that we delete calls older than 2-3 months from the call logs.
Now I am facing the following problem:
Under Reports - Settings there is the item clear call logs.
On the one hand, the area to be selected makes no sense here. You can only delete "current" calls here, like for example the last 30 days. But that doesn't make much sense here, who wants to delete them, it would make much more sense to delete anything older than 30 days, so that the last 30 days are preserved.
On the other hand, if I set up a user-defined area here (German translation for this is currently "Benutzerdefinierte Vorlage") and confirm it with Delete, then it supposedly deletes and also shows me a number, how much it has deleted now, but I still have calls in all call lists that go beyond the now remaining area and also the call list on the dashboard does not change the number. Even the logs of the users in the clients are still displayed from the time period that was actually cleared.
If you click on the button Clear call log on the dashboard, you can unfortunately only delete all calls. But this is stupid with running queue reports for the controlling department, because then you always get into either the monthly or the weekly reports and then they are incomplete.
Could you please clarify why deleting a user-defined area of the call logs has no effect on the call logs or what exactly is deleted here?
Of course it would be nice if the item "Delete call logs" could be found in the call log instead of in the reports and if you could also define a time period in the dashboard under call history, so that you can exclude the current reporting period.
It is even written here that you should delete the call log from time to time. I would like to limit this to a certain period of time.
Thank you.
Hi Phil,
If you delete for example from 01/01/2010 to 31/08/2020 23:59 you should end up with just the records of September.
This means you will get rid of everything except the last month.
Hi Phil,
Hi, first, this is not the only problem out of my thread. You just picked the most unimportant problem. I know it would work that way, but don't you think it would be smarter not to have to options like "last .. days/weeks/months", but rather have options like "EXCEPT last ... days/weeks/months"?
But as I said, these options and the "custom template" are not the main problem. The main problem is, that even the custom template does not clear anything from any call list.
The call logs and the number of calls in the dashboard, even every call logs from all clients are the same as before, but when I click clear in this reports settings, it only tells me that it deleted call logs for one time. If I try to delete the call logs in the same custom template again, it says "0 record(s) deleted".
Hi Phil,
I would like to inform that this has been added to our roadmap, but I cannot provide an ETA at the moment.
  • Love
Reactions: PhilK
hughesdouglas
