Config SIP Trunk Inbound Params and Access to Management Console via setupconfig xml
Koushal
New User
I am using the below method to being the 3CX system installed in my server and need help on configuring the below two items using the xml file.
https://www.3cx.com/docs/configure-pbx-automatically/
Can someone please help on how I can do this with the help of xml file?
1. Under SIP trunks -> Inbound Parameters -> Caller Number/Name Field Mapping -> "CalledNum" number that has been dialed (default: To->user)
=> The value for the above to be set as P-Called-Party-ID: User Part
2. Under Extensions -> Rights
=> I need to enable the "Allow access to 3CX Management Console" option.
Thanks in advance.
Hi!
I'm afraid these 2 things can't be set via the setupconfig.xml file.
An option could be to make a backup from an existing 3CX installation and set everything up as you want, then you could restore this backup using the setupconfig.xml file, essentially using the backup file as a "template".
Reactions: Mike Hammett
Ok. I thought it will be useful if we have this support in setupconfig.xml file.
Thank you for the reply.
Reactions: NickD_3CX
fngl
