Configure dot1x via template?
newuser1
I am wondering if I can configure PEAP/mschapv2 for our Yealink phones via a template since I don't see a way from the 3CX Management console for my Yealink T42/T48 phones? Or do you have to rely on MAB for authentication if switch port is enabled for authentication?
I don't recall ever seeing this question asked here so you are probably better off asking in the Yealink forums if you haven't already. But if that is something that can be configured in the web interface then yes it should be possible via template.
The parameters are available in the template, but you have to set up them manually.
Do a search for network.802_1x. and you will find them.
Wecare_ITA
