Solved Configuring W70B (W73H handset) with 3cx error
adm3cnew
Hello Team,
I configured the 3cx and Dect as attached photos.
1- I reset the Dect (W70B)and registered the Handset(W73H) and I updated firmware to 146.85.0.40.
2. I configured the 3CX (please check the photo ) by creating a new extension (103) and added the Dect.
3- I downloaded the auto-provisioning file and uploaded on Dect page.
4- the extension number (103) has shown on the handset's screen but cannot call and the extension status on Dect web page is disabled.
Thank you in advance,
You're using STUN and unsurprisingly facing issues with it.
1. install an SBC at the same location as the W70B https://www.3cx.com/docs/3cx-tunnel-session-border-controller/
2. Change the W70B settings in 3CX to use this SBC you just created.
3. Reset and reprovision the base with the new config.
PS: I also see you are a paid customer on V18. This version will become EOL at the end of the year, so please consider upgrading to V20 soon to keep enjoying your product: https://www.3cx.com/blog/news/v18-support/
This solved the issue completely. I really appreciate your help.
Thank you so much :)
Reactions: JohnS_3CX
Finatra.us
