Conflict with Slack's Nebula
GordonShumway
Forum User
  • 3CX Version: Standard Annual 16.0.4.493
  • Server OS: Debian 9.11
  • 3CX Server Hosted: Google Cloud (micro-f1)
I have freshly provisioned this VM (thru 3cx deploy feature) and restored a previous VM backup (without the key/FQDN), but I'm pretty sure any existing 3cx instance would be affected.
When I run the Slack's Nebula node (https://github.com/slackhq/nebula, the binaries are lightweight) on port 4242 on the same VM, the 3CX SIP Server component stops and cannot be successfully started/restarted until the Nebula service is stopped.
Is that a port collision? Can I just run Nebula node on a different port to keep the 3CX SIP Server component happy?
I'd like to run Nebula to hide the SSH behind it, while leaving every other port open.
Not sure if it's a port conflict, but Nebula is essentially a VPN and 3CX does not support having VPN on the 3CX instance. As far as a port conflict. Just look at the ports when 3CX is running and Nebula isn't.
Well, I haven't seen anything on 3cx to suggest it is using port 4242 which is being used by the Nebula node.
Can I tag any of the 3cx people in this thread to get an official reply? Since 3cx is commonly run on the internet-facing VMs, hiding SSH port behind the Nebula node sounds like a great idea.
Also just FYI micro-f1 is too small, we recommend G1 as a minimum
https://www.3cx.com/docs/recommended-hardware-specifications-for-3cx/#h.4z53dfbtxlno
Services may shut down when there aren't enough resources so you should build a bigger machine that doesn't have a shared CPU (if you want to test it).
We do not support having any other services on the machine, we don't know how they will interact or affect your instance.
Innovative Advisory
