Contact lookup wouldn't repeat if 10 minutes not passes
YuriiITE
New User
I have my own integration template, that is configured to make contact lookup always (not "when contact is not found").
I've found out that if the same number calls more frequently, than once a 10 min - the lookup doesn't starts.
The best solution for me is to start lookup even if contact calls two times in a row. But if there is now such way, maybe I can configure the period (change from 10 minutes to 1 minute)? Maybe, there is some param?
What version of 3CX are you using?
Reactions: edossantos
That cache has been removed, if you upgrade to the latest version of 3CX you will not have that issue.
EMMEPICASA
