Continous Active Call , how to abort this
Syed hamza Faiz
Hey ! members and official support Team
i am facing this issue , there is a active call in my log , but physically there are no calls active . i have tried to cancel this but not even cancel worked , kindly need suggestion , should i restart services ?
Scree Shot Attached !
Regards
Syed Hamza Faiz
Reactions: tyenglish
If you cannot drop the call via Switchboard or in the management console, you will need to restart services. Just make sure nobody is on a call or needs to use the system, preferably after hours.
Maybe try another browser to start with?
actually the problem is , i have 2 PSTN lines , if i call to my 1st PSTN line call diverts to IVR then IVR diverts the call towards extension , in my senario , if station is busy the call will be forwarded to my outside number , its working fine but the problem is , when the call diverts it shows its connected in the status even after both parties hangup the call .
the status shows call keep connected , this causes line busy .
if call stay active even when callers hang up , surely no bye signal is received or a misconfiguration on your gateway
