Copy Incoming Phone Number
siscom
Good Morning Colleagues
I hope you are doing good and save.
One of our customers is using 3CX softphone for Windows 10 for his agents . Is there a way to copy Incoming calling number to notepad - manually- by an agent while the call in progress ?
Best Regards
Hi @siscom,
There is not a way to copy it out, but you could make a notepad document and resize it smaller and type it off as you're on the call?
What is the reason you'd need the caller's number in a notepad doc during the call?
Hi Vasilis
Thx for your advice . The case that my customer is a restaurant and he needs the agents to be able to record the calling number very fast before taking the order from the customer calling the restaurant to deliver it to him.
Best Regards
This sounds like something a CRM could handle automatically for them. Have you checked out our supported CRMs?
Well Noted . Thanks Vasilis for your feedback
it's already noted in the call history, just take it from there?
florentrobineau
