Solved Cosmote - 3CX - debian V.20
mikeB200
Forum User
Hello.
could someone please post a step by step how to setup properly a trunk for COSMOTE greece a head number and all MSN?
I need to convert my ISDN like which now connects via oxygen router to a PATTON gateway directly to 3CX due to issues of compatibility.
many thanks
Hi there.
Since it is not a supported trunk, it will be difficult to advise, however, you can have a look at this post.
Reactions: mikeB200
Yes, I can confirm it worked ok. thank you
May i suggest that for outbound rules you have to enter in Callet ID section the number in format +30XXXXXXXX otherwise the extension gets a message the number is blocked etc..
Great!
Regarding the rules, are you referring to the prefix in the outbound rule?
If so, then in the outbound rule, you can have 0-9 as numbers, or if it is a sign use + or combination, for example: +30.
If the number matches the call will be sent to the destination you have there, trunk, gateway etc.
See more examples here and here
Reactions: mikeB200
Hey mikeB200
could you please post the settings you used, and you got connected???
In the post mentioned above, several different settings are being suggested.
Thank you!!!
Hi there.
I have implemented these settings to my Cosmote trunk as well.
hope it helps.
Screenshot 2024-06-11 at 7.16.34 PM.jpgScreenshot 2024-06-11 at 7.15.41 PM.jpg
Reactions: OlegR_3CX
Great to hear the solution is found and issue is resolved.
I will now close this thread.
Have a nice days guys
mpeyruchat
