Solved Creating a 3CX Lab when a prod is running
NealONeal
Hello there,
I'm trying to setup a Lab 3CX server in my network, but there is already a production 3CX system running on the Public IP Address.
I imagine I can't have both systems using the same Public IP address, no ?
Is there any way for me to have the production 3CX system and a Lab one ?
Thanks a lot for your help.
That is correct, you can not have two systems on the same wan IP address - you probably will have issues with licensing, updating fqdn , 3cx ssl certificate
Also you will not be able to setup porting forwarding
FYI. You can not run the two 3cx system using the same license key - the lab server would need a different license
Hi @NealONeal,
While we recommend 1 public IP per 3CX installation for a production system, to avoid any port forwarding issues. I can tell you that if you accept the limitations and wish to install two, the installer won't check and stop you from installing two PBXs behind the same public IP.
Reactions: NealONeal
You'd be better off getting a VPS for cheap.
OVH can sort you out for £3 per month
I'll have to check with my Network engineer if we have more IP addresses.
I'd love to install a Lab 3cx to practice for the 3cx certifications.
@Saqqara I know about the two keys needed, I got another one specially for the test one.
Thanks for your answers, I'll have to do things differently to avoid any issue with the production.
Reactions: VasilisV_3CX
Sure thing @NealONeal, feel free to open a new thread if you require any further assistance!
mazet
