CRM integration for external callers
joerg.schulze
We have a CRM integration that performs a lookup in the database for incoming calls. Unfortunately, this only works for externally incoming calls, not for internally incoming calls.
Is it possible to enable this for internal calls as well?
Just to clarify -
Calls from outside number to your PBX register and calls from your PBX to outside numbers do not register?
The CRM, it is a custom setup or are you using one of the 3CX provided integrations/templates?
CRM integration only works for external calls, even transferred ones. But not for internal calls and it cannot be enabled, as it's hardcoded.
outside calls work fine. Only internal calls from one user to another are not shown on out 3CX provide CRM integration.
And that's by design.
Internal calls don't trigger the CRM integration. To get that you will need to create something custom using the Call Control API.
For CRM integrations I would start with Evolute IT
LVCC_Admin
