- Joined
- Dec 22, 2020
- Messages
- 7
- Reaction score
- 0
Hi, we’re using the crm integretion trough the xml file ( and the crm software from the website ).
With that we’re trying to get contacts information from our crm software to show the contact information ( name, surname and company ) on our phones.
When the call arrive the request return the correct datas ( seen trough the log file ). And the 3cx creates a row inside contacts with the “CRM” tag.
But on the first call the phone show the phone number and not the name I’ve returned from the request.
If the user call again within 10 minutes, it start to work correctly and show the correct surname, name but after 10 minutes the row created inside contacts is deleted and at the next call it start again not working
Is there a way to solve this problem?
Example
1)Caller number: 030123456
2)Response from crm:
Surname: “Doe”
Number: 030123456
3)Data saved TEMPORARY inside contacts
Surname: “Doe”
Number: 030123456
4)TEXT SHOW ON THE PHONE
030123456
5)Call again within 10 minutes
Caller: 030123456
“Doe, John”
AFTER 10 MINUTES EVERYTHING RESTART FROM POINT 1
So basically on the first call every 10 minutes the crm data are ignored and the phone shows only the caller number and not the data I need ( and send correctly ) from the CRM
Example
Surname: “Doe”
Number: 030123456
Surname: “Doe”
Number: 030123456
030123456
Caller: 030123456
“Doe, John”
