CRM Integration template : contact url is wrong
virtuOS
Forum User
I configured a new template for a CRM Integration with telsearch.ch but the URL contact page isn't correct.
3CX open this url http://tel.search.ch/result?was insted of http://tel.search.ch/result?was=THENUMBER.
I would like to know how i can do that ? I try with the contacturl but without result....
Here a copie of the template :
<?xml version="1.0"?>
<Crm xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" Country="CH" Name="TelsearchCRM" Version="1" SupportsEmojis="false">
<Number Prefix="AsIs" MaxLength="[MaxLength]" />
<Connection MaxConcurrentRequests="2" />
<Parameters>
<Parameter Name="APIkey" Type="String" Parent="General Configuration" Editor="String" Title="API Key:" />
</Parameters>
<Scenarios>
<Scenario Id="" Type="REST">
<Request Url="https://tel.search.ch/api/?was=[Number]&amp;key=[APIkey]" MessagePasses="0" RequestEncoding="UrlEncoded" RequestType="Get" ResponseType="Xml" />
<Rules>
<Rule Type="Any">entry.id</Rule>
</Rules>
<Variables>
<Variable Name="ContactID" Path="entry.id">
<Filter />
</Variable>
<Variable Name="FirstName" Path="entry.firstname">
<Filter />
</Variable>
<Variable Name="LastName" Path="entry.name">
<Filter />
</Variable>
<Variable Name="CompanyName" Path="entry.title">
<Filter />
</Variable>
<Variable Name="Email" Path="entry.extra">
<Filter>
<Rule Type="Equals" Ethalon="email">entry.extra.type</Rule>
</Filter>
</Variable>
<Variable Name="ContactUrl" Path="entry.businesslink">
<Filter />
</Variable>
<Variable Name="PhoneBusiness" Path="entry.phone">
<Filter />
</Variable>
</Variables>
<Outputs Next="" AllowEmpty="false">
<Output Type="ContactID" Passes="0" Value="[ContactID]" />
<Output Type="FirstName" Passes="0" Value="[FirstName]" />
<Output Type="LastName" Passes="0" Value="[LastName]" />
<Output Type="CompanyName" Passes="0" Value="[CompanyName]" />
<Output Type="Email" Passes="0" Value="" />
<Output Type="PhoneBusiness" Passes="0" Value="[Number]" />
<Output Type="ContactUrl" Passes="0" Value="http://tel.search.ch/result?was=[PhoneBusiness]" />
</Outputs>
</Scenario>
</Scenarios>
</Crm>
Thanks for your help.
Best regards
Probably because you assign [PhoneBusiness] from entry.phone, which might be empty, but do not use it in the output. You use it only for the URL.
In your case, you can probably use [Number] instead.
I call with an external number which work when i test :
"UnparsedOutputs": {
"ContactID": "",
"FirstName": "",
"LastName": "VIRTUOS IT SA",
"CompanyName": "",
"Email": "",
"PhoneBusiness": "0274565666",
"ContactUrl": "http://tel.search.ch/result?was=0274565666"
"FirstName": "",
"Email": "",
"ContactUrl": "http://tel.search.ch/result?was=0274565666",
"CompanyName": "",
"PhotoUrl": null,
"ContactType": 0,
"PhoneBusiness2": null,
"PhoneHome": null,
"PhoneHome2": null,
"PhoneMobile": null,
"PhoneMobile2": null,
"PhoneOther": null,
"FaxBusiness": null,
"FaxHome": null,
"Pager": null,
"ContactRawData": null
You think i have to restart the application or a service ?
Best gegards
When your call comes in, make sure the caller ID is in the right format so that it can search it. If it has more digits, it won't work.
