CRM Template indicate line/DID used at any stage?
wsd-tim
I prefer to have the information at contact lookup stage, but call report stage is okay as well. I just can't find out how to get that information at all from the CRM intergration.
OR I'll settle for the call_id or callhistory_id from the report calls so I can match CDR logs, but that seems to be missing as well
Thanks for the heads up. Coming over from FreePBX, setup was much easier, Mobile App actually works, but lost a lot of freedom. Hope REST API can come out full force before our subscription renews in SEP
I guess just have to do a match for start time and number from CDR
Yes, in the CDRs you have more information available, so you can use it to complete your data.
But only unsupported database read for segment data. Even then, it's not live at time when segment ends, only when whole call ends :'D
Yes, this is correct, the information is written to the database a few seconds after the whole call has finished.
lastshadow
