CRM Zoho : Only http and https scheme are allowed (parameter value)
JimmyP
Gold Partner
Hi there!
Trying to connect a client 3CX with there Zoho, I'm getting this error :
More infos :
I try to set up the system for a client. It's my first time so I got some issue :
I tried to create a Zoho token with my own zoho account, and it seemed to be working. But the client deactivated my account, and it stopped working.
So Now I asked them to create the token, and I put it in 3CX CRM section and "authorized" it myself. This is how I got the error.
Do I need to have them authorize the refresh token via 3CX CRM with there own Zoho account? Is this why I get the error?
Thank you!
Yes, you need to authorize the Zoho from their account using THEIR developer console Client ID and Secret.
Also, make sure to enter the Return URL in Zoho correctly: "https://<FQDN>:<443/5001>/api/oauth2crm"
Reactions: JimmyP
Graham Robertson
