Crowdstrike Endpoint Security Detection re 3CX Desktop App
wars
Hey,
(Posted this in the wrong section so deleted and moved it here)
So, we use Crowdstrike Falcon Overwatch and about half an hour ago I had an alert come through (something which only happens a handful of times a year) telling me that the 3CX Desktop App has been attempting to communicate with a 'highly suspicious domain, likely to be actor controlled.' - msstorageboxes[.]com - I have looked this up and it appears to be owned by someone/something in Reykjavik.
https://intodns.com/msstorageboxes.com for more info.
I raised a ticket and have been told that I should do this through the portal at a cost of £75. This isn't something I am happy paying for, as the alert points to the 3CX Desktop App having the issue, NOT anything to do with our infrastructure. So, here's my forum post.... I've removed the desktop app and asked the user to access it via the webpage which works just as well, I think he is the only one with the full app installed anyway. What I want to know is, what was the app doing? Does 3CX recognise this domain?
Full alert is -
Falcon OverWatch has observed connections to known malicious infrastructure by the 3CX Desktop App process on this host.
DNS : msstorageboxes[.]com
NOTE: Highly suspicious domain, likely actor controlled.
This has been raised for immediate action and should be investigated urgently.
Due to the identified activity in relation to the 3CX Desktop application, we would recommend removing this software from your environment, (both Windows and Mac) where applicable and if possible.
Reactions: Nathan@Voxtelesys
MsiExec.exe /X {EFC8D3F7-8A56-430E-93D3-C7AF626123CB} should do the job
If the GUID is incorrect, you can find it on a sample machine by looking in the registry - this should point you in the right direction -
https://www.advancedinstaller.com/msi-retrieve-productcode.html
If you are using RMM or whatever, this will work as well.
$app = Get-WmiObject -Class Win32_Product | Where-Object {
$_.Name -match "3CX Desktop App"
$app.Uninstall()
That said, I am waiting until there is something official out from 3CX. Which I hope is soon.
Reactions: Tony Cave
I only have one user with the client installed and it appears to have been dormant (or he was using the web client version) till this afternoon at 13:52GMT which is when it all went a little crazy. Thankfully no other users have the client installed so it's had a low impact for us.
I should say it was the AI that got it. So if you don;t have that turned on, you wouldn't have caught it.
From my 3CX rep:
Yes, we are aware and the 3CX Desktop Application Virus Vulnerability has been reported. Please open a support ticket and in the meantime please just use the web client.
From 3CX Support:
Just so you know, the issue reported is due to some virus scanners picking up the desktop app as a virus for some reason. We are looking into this and will get back to you as soon as we have further information.
3CX should probably make a public (or at least a forum) posting about this soon, at least to allay some fears from the community.
Agreed, I just called them about that and they said that they don't have enough evidice about what is actually happening to make an announcement. But they said they have their security expert actively working on this and will post something once they know what's going on.
Sophos MDR just issued this:
// Overview 
Leveraging open-source intelligence, MDR Operations has observed the popular Voice Over Internet Protocol (VOIP) client, 3CXDesktop, being actively used in an ongoing campaign.
The software is a digitally signed and trojanized version of the softphone desktop client for both Windows and MacOS. The most common post-exploitation activity observed to date is the spawning of an interactive command shell.
Some security researchers suspect this activity to be state sponsored, however we cannot verify this attribution with high confidence at this time.
// What you should do 
Stay alert for communication from 3CX either directly or on their forum
https://www.3cx.com/community/forums/webrtc-webclient/
Identify systems running 3CXDesktopApp.exe process and document the version, hash, and last update date time. It has been reported that the impacted versions are 18.12.407 and 18.12.416 for Windows and 18.11.1213 for MacOS. Typical installation paths include:
*\ProgramData\3CXPhone (Windows)
*\AppData\Local\Programs\3CXDesktopApp (Windows)
/Applications/3CX Desktop App.app (MacOS)
In the event any suspicious activity is observed from these hosts, consider network isolation until detailed vendor guidance from 3CX has been issued
Uninstalling is proving difficult because the application installs in the appdata folder, which doesn't work with the PowerShell uninstall method.
  • Sad
Reactions: Nick W
The MSIEXEC Method wont work either in /qn mode
S1 ai module actually picked this up a few days ago. We thought it was a false positive.
Same here. Busy undoing all the exclusions we put in place at the moment.
Unfortunately the rumors are true. Please uninstall the client. And we will have a new one in the next few hours via updates.
The updating probably wont work because Windows Defender will flag it.
Unfortunately this happened because of an upstream library we use became infected.
Hi Nick, Thanks for the update. One of the infected versions it seems was the Jabra SDK version. Do you know if the updates will provide a clean version with the Jabra SDK? Thanks : )
Jabra SDK works with PWA too, no problem.....
But yes new MSI will have jabra API support
Reactions: akissick
BIT Incorporated
