CSV export of Extensions
Yellow_Flash
We are running v 15.5 SP6 on one of the install and v16 on the second one.
Is it possible to export the extensions from one install and import it onto the other one?
Say, the extensions are exported from the install abc.3cx.com(v15.5 SP6)
Can the extensions be imported to a different install def.3cx.com(v16)??
If so, what all information will be imported?
Will the MAC of phones be included in the csv file?
I believe the forwarding rules and DDI's wont get exported with it.
All I want to do is export a few extensions(50) and import them on to a new install, and register these extensions with different phones.
Can someone please let me know what would be the easiest way to get this done?
Thank you
So about half your questions can be answered by clicking the export button and then looking at the CSV file. The rest can be answered by attempting to import. Don't want to make a mess? Export a single extension and then import it.
There's also this:
https://www.3cx.com/docs/bulk-extension-import/
Also please don't forget to reset and reprovision the phones when you are done.
With V16 you will probably also receive firmware updates for those devices so that the V16 templates can provision the phones correctly.
3K8iMGWviZ
