Curious call log entry / connection from external to external
Andreas Conrad
Platinum Partner
Hi there 3CX community,
I got a curious case of an extension seemingly initiating an external conference call and then those external numbers calling each other?
Sadly those call logs are all I have, no pcaps or higher log levels -> 3CX support couldn´t really help.
The 3CX extension was compromised during these events.
Whats the most plausible explanation for this kind of call log entry ?
kind regards
case solved, it´s the entries you get from
internal extension -> external A
attended transfer -> external B
complete transfer
and is a technique used to max out the lines in a compromised 3CX if you only breached one extension.
Not used to seeing transfers to external, so it looked strange to me.
VR46
