Custom salesforce integration
Juan Marriott
Hello, I am looking for a custom integration with salesforce; I need to ask the caller for an ID then look up on salesforce with that ID instead of the callerID
Any ideas or recomendations?
CFD + CRM Lookup components.
Reactions: GregG_3CX
So, it can be done?
Hello Edossantos,
Need a little help here:
Task: customer have salesforce, but doesnt want to use "callerID" for the CRMlookup. Want to use "studentID".
I have already on CFD:
1.user imput
2.promt user imput to confirm
3. custom CRM lookup (worlikng on this)
4. should I modify salesforce template to use "studentID" instead of "callerID"?
5. Do I need to use "attach call data"?
No, when invoking the CRM Lookup component, you have different types of queries. If you use "Custom Query", you can specify the filtering options you want. If you check the standard template we provide, you will see that when executing this custom query, 3CX will invoke the Salesforce REST API using this endpoint:
[Url]/services/data/v55.0/search/?q=[Query]
Here's the documentation from Salesforce regarding this endpoint:
https://developer.salesforce.com/docs/atlas.en-us.api_rest.meta/api_rest/resources_search.htm
Then, you can create an SOSL query to filter contacts according to your needs.
If you then need to transfer the call to a queue, and let agents see the contact details, then you will need to attach 2 properties to the call:
1) public_lookup_displayname_override > This is the contact name to show
2) public_crm_contact > This is the JSON of the CRM search result, which in your case you will need to build:
JSON:
    "FirstName": "John",
    "LastName": "Doe",
    "Email": "[email protected]",
    "ContactUrl": "https://example.com/contacts/42013984654",
    "CompanyName": "",
    "PhotoUrl": null,
    "ContactType": 0,
    "PhoneBusiness": "+123456789",
    "PhoneBusiness2": null,
    "PhoneHome": null,
    "PhoneHome2": null,
    "PhoneMobile": "",
    "PhoneMobile2": null,
    "PhoneOther": null,
    "FaxBusiness": null,
    "FaxHome": null,
    "Pager": null,
    "ContactRawData": "42013984654|Contacts"
Hi @edossantos,
I appreciate your help we were using the attached data with "public_crm_contact_url" to set a custom screen Popup but after the update seems this not working or changed to another name do you idea about the new value name or where I can find it.
Thanks in advance
Hi @edossantos,
Thanks in advance
Yes, this has changed, check my response above, the details are there.
Hi @edossantos,
many thanks for your prompt reply,
I already try to change the value of attach data to be "public_crm_contact" but it's not working,
can you clarify what you means by "This is the JSON of the CRM search result, which in your case you will need to build:"
As in our case we use the attach data only without any CRM integration
Hi @edossantos,
Can you show how you're attaching the public_crm_contact property? How you're building this JSON.
I don't have CRM integration at all I just attach data with the URL then transfer to queue and it was working fine before the update
I understand that. But what expression are you using in your CFD app to create the value for the property public_crm_contact?
attached
You're setting the property to an URL. But you need to set it to a JSON, which must have a property for the URL. The property should be set to something like this:
JSON:
    "LastName": "Doe",
    "CompanyName": "",
    "PhotoUrl": null,
    "ContactType": 0,
    "PhoneHome": null,
    "PhoneHome2": null,
    "PhoneMobile": "",
    "PhoneOther": null,
    "FaxHome": null,
    "Pager": null,
I got your point the misunderstanding was due to the old version accepting URLs only,
thank you
Reactions: edossantos
Graham Robertson
