Custom Template for Snom 7xx phones
winston bolt
I would like to create custom templates for my Snom Phones - mainly for the function keys as all users have different function key setups.
Currently I have the function keys setup on a few phones locally, and those phones are set not to auto-provision. Is this the accepted method?
I would like to have them set to auto provision with their custom template.
It would be great if someone could supply me with an already filled out custom template.
I've pulled the XML settings - but translating that back into the custom snom template is a bit difficult.
What do you need to use custom templates?
if you want 3CX support and provisioning better to stay in default template.
All BLF can be set in MC per extensions and provision on phones
Hi Winston,
Auto-provisioning is the recommended method, and it allows you to set the BLF buttons to various options as seen here:
12039
We would not recommend using a custom template, only do it if it's absolutely necessary to you for very specific requirements but keep in mind the phones are not guaranteed to behave correctly when making custom templates.
[email protected].
