- Joined
- Jan 13, 2015
- Messages
- 146
- Reaction score
- 13
I have used a custom template for years for some Grandstream handsets that we use. Never had any problems. I have always dumped the template into "ProgramData\3CX\Instance1\Data\Http\Templates\phones" so that it would just show up as a normal template instead of red text.... Now after update to SP4 it is no longer available to select in the drop down. I can export / import an extension to force it but that is a little silly. Did something change on the 3CX side? Trying to force us out of adding templates to the native template folder?
