Dashboard event log sometimes shows events in non-temporal ordering
mdeek
Noticed this today; sometimes a trunk or two become unregistered and immediately re-register successfully (I assume these are caused by the occasional hiccup on the internet line or perhaps the ISP's SIP servers). Looks like if it happens quickly enough, the event log doesn't sort them correctly any more. Specifically, it only seems to use whole seconds to sort entries.
Just in case you were not aware, please note that you can also manually trigger re-registration when entering the SIP trunk settings, and pressing OK.
Reactions: mdeek
Yeah, I have had an eye on the re-registration thing for a while. So far I can't see a pattern, it certainly isn't connected to calls being active, since it happens if no one is using the system at all. It doesn't disrupt ongoing calls and since the trunk stays unregistered for three seconds tops, I'm not too concerned about it. (We have a few incoming calls per hour, not per second).
"Just another weird thing sometimes happening with SIP stuff"
I would not pay much attention to it if there is no impact. If you notice any issues with calls however, definitely worth investigating with Verbose logging enabled.
Reactions: mdeek
