Data Archiving - Recordings
smaloney
I received an email today indicating that my Recordings Storage has reached 75%. I went to investigate. It appears Auto-archive for Recordings stopped working about 2 weeks ago on 4/23/2026.
The "Move to Archive" button is unclickable and the icon is a spinning wheel.
  • I have verified the SFTP credentials are still valid and I am able to manually archive Recordings.
  • The backup server is not at capacity.
  • I have turned on/off Auto-archive for recordings; turned on/off Enable Remote Data Storage & Archive; turned on/off call transcription (suggested in another thread).
  • I have not rebooted the instance (I'll have to try this after hours, if necessary).
Any other ideas?
(Notes: Type Enterprise+8; on premise install; Version 20.0 Update 8 (Build 1121 Release); Remote data storage is via SFTP w/ Password)
Please check the Integration > Transcription section. Is this showing RED? If so, set it to OFF, save, then restart the 3cx services and try the remote archive again.
Then, if you have the Ent + subscription, re-enable the transcription.
ARKC
