Debian does boot without a monitor, Help!
ECOM GROUP (Mauritius)
I just installed 3CX ISO Debian 9 on a mini pc, everything went fine, Now i noticed when i have disconnected the monitor the monitor, Debian does not boot. on off on off still does not boot. when i connect a monitor to it, then it boot as normal. Is there any fix for this since the mini pc is acting as a 3cx server which i dont need a monitor to be attached to it
thanks,
@JohnS_3CX @cobaltit @diamond9 @complex1 @Cjay
What type of mini pc you use?
Is the monitor connection a VGA port?
Check the BIOS
Check the BIOS
@complex1 I have a Gigabyte brix J1900, in the bios, i have set it to power on automatically if there is a powercut.
i found this weird, any idea why it only boot when i connect a monitor? its a VGA
You need a VGA (dummy) plug which emulate a monitor.
This will solve the issue.
You will need a dummy what is emulate a monitor.
VGA to HDMI convertor don't work.
Please try (buy) a VGA dummy plug.
Probably you can buy one at the local computer store.
No bios update with improvment on this part?
  • Sad
Reactions: AWS2P
is it a poor bios with very few setting change available?
If you read @cobaltit post you have the solution without buying any dummy plug.
@Zol Yes now i am checking it, i did not pay attention, thanks
Thanks @Cabaltit as well
natedog
