Debian install failing
Chin007
Intermediate Cert.
Have installed debian before but this time after the install, it does not give you the option screen if you want to use command line or web interface to configure 3cx. Instead, it restarts and takes you to a login screen.
Has anything changed? I can login to the debian and ping to make sure i am connected to Internet.
I have deleted VM and created new one but each time same issue. I have downloaded the newest debian 3cx install and same issue. What could i be doing wrong?
Hi!
I have just tried the ISO that is available in the Customer Portal (the one you say isn't working) in a VM as well and it loads the menu just fine.
Note that ISOs need access to the internet to download the script required to show the menu, so if there is any network or DNS issue, that could be causing this.
Not sure it has to do with network. Its same vm but the other iso works.
I even tried a manual install on debian. It downloaded the 3cx but said the dependables are not installable.
Something not right with the iso. Although i used it last month and everything was fine. Glad at least i have a working iso for now.
Chin
Mr_IT
