Debian Update failed
Artur.O
Hiya, we have 3CX on provided debian iso. We didn't update it for a while and have it on 15.5.15502. I tried to update it this week with the upgrade button but it failed. I don't have ssh access so I wanted to do it over the webpage. Here are the logs:
Bash:
--2019-10-26 10:33:41--  https://downloads.3cx.com/downloads/misc/debian8to9/update.sh
Resolving downloads.3cx.com (downloads.3cx.com)... 151.80.125.73
Connecting to downloads.3cx.com (downloads.3cx.com)|151.80.125.73|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1245 (1.2K) [text/html]
Saving to: ‘/tmp/update.sh’
     0K .                                                     100% 30.6M=0s
2019-10-26 10:33:41 (30.6 MB/s) - ‘/tmp/update.sh’ saved [1245/1245]
/tmp/update.sh: line 1: !DOCTYPE: No such file or directory
/tmp/update.sh: line 2: html: No such file or directory
/tmp/update.sh: line 3: head: No such file or directory
/tmp/update.sh: line 4: meta: No such file or directory
/tmp/update.sh: line 5: title: No such file or directory
/tmp/update.sh: line 6: style: No such file or directory
/tmp/update.sh: line 7: !--
/tmp/update.sh: line 8: body{margin:0: command not found
/tmp/update.sh: line 8: font-size:.7em: command not found
/tmp/update.sh: line 8: font-family:Verdana,: command not found
/tmp/update.sh: line 8: background:#EEEEEE: command not found
/tmp/update.sh: line 8: $'}\r': command not found
/tmp/update.sh: line 9: syntax error near unexpected token `}'
/tmp/update.sh: line 9: `fieldset{padding:0 15px 10px 15px;}
The update file doesn't exist anymore. Any suggestions?
Hello @Artur.O
The update procedure through the PBX to upgrade from Debian 8 to Debian 9 does not work any more to prevent any damage to the system since there have been many updates to Debian 9 and the procedure no longer applies.
You will need to perform a full backup of the system, save the backup away from the machine and then un-install and re-install Debian 9. You can then also update your PBX to the latest version using your backup.
Wecare_ITA
