DECT Comes Easy for 3CX Cloud Phone System U7
N_G
Founder
Improved SIP Trunk options boosts number of supported VoIP providers.​
DECT phones and VoIP Provider support are THE Update 7 buzzwords. Read on to look back upon the major milestones of Update 7 including how to access it and how to register at our interactive U7 Webinars to discuss it further. We invite you to have a read and ...
And now I can't wait for U8 Beta :)
This is really cool. Especially when used with Snom D862 or D865 with built-in SBC. We tested it and it works like a charm. Solid solution!
@Bas - thanks for the headsup!
Reactions: Bas Nederveen
regarding DECT in version 7, when using an ATA defined under the DECT section, can we now select the router phone as the SBC for the DECT ATA?
Currently this only adds support for DECT devices (not ATA / FXS).
However, if you have a dedicated system you can make the change via the management console and have your router phone selected as the SBC for your ATA.
Is this new in V7 because I recall I could not do that back in January?
Reactions: JohnS_3CX
Hello, we are currently experiencing an issue regarding the deployment of 3CX on Azure. I don't know if this is related to recent events but when we want to deploy a virtual machine from the PBX we don't have all the Azure VM bundles available. Also the 3CX Azure application has disappeared. What can we do ? Thanks in advance
I spoke to support on this today. I believe the Marketplace Azure 3CX installation is coming back, within a few days.
I don't think so to be honest. This is a decision made by Azure, not us.
Reactions: Nick W
Noted! This came from support, sorry if it was misinformed! I hope Microsoft make the right decision and put you back!
Reactions: N_G
Hassan Murasan
