Improved SIP Trunk options boosts number of supported VoIP providers.
DECT phones and VoIP Provider support are THE Update 7 buzzwords. Read on to look back upon the major milestones of Update 7 including how to access it and how to register at our interactive U7 Webinars to discuss it further. We invite you to have a read and share your thoughts with the Community too.
New Easy DECT Configuration: What This Means
In a nutshell, we simplified the setup and support for DECT phones. This means you can easily configure a base station and then assign handsets to users from the “Users” tab. If you’re in the cloud you need to do this behind an SBC router phone. We have an extensive list of end-to-end supported devices, including now the new Snom M400 DECT, with guides for each:
DECT phones use case
DECT phones! Mobiles that aren’t mobiles bring a wide range of benefits to any business. In a restaurant, for example, DECT phones provide excellent voice quality for staff. Running on a separate frequency range independent of WiFi, they’re not subject to interference. Even better, they allow staff to communicate with each other over a long distance. If your staff are few and the area small, then one base station and a couple of low-cost handsets are all you need. As your business and staff grow it’s possible to scale up and use several handsets at the same time and at several base stations.
DECT phones are hard-wearing and long-lasting and almost impossible to break. If broken, no data is lost and it’s easily and cheaply replaced. They’re energy-efficient, and with all internal calls free, it’s communication at zero running cost. And from a business point of view, no constant interruptions for staff with the latest notification!
In summary, why DECT phones are a good business choice
- DECT is more reliable than WiFi for voice
- No need to use personal phones
- Cheap, long-lasting, easily replaced hardware
- Long battery life
- Scale up according to business needs
Extended VoIP Provider Support
We’ve expanded the number of VoIP providers you can configure from our new web admin console. This increases the number of SIP Trunks available for use with all 3CX editions, particularly Hosted and StartUP.
- You can configure an optional three-way authentication ID for those providers that support it
- It’s now easy to support providers that have TLS where 3CX does the certificate management automatically
- You can configure both IP-based and registration-based Generic providers
- The Generic SMS/MMS API has been updated to allow third parties to develop and support SMS on 3CX
We now support many more providers out of the box. Some prominent ones include:
- Germany’s Deutsche Telekom’s CompanyFlex
- Vodafone in the UK
- Bouygues Telecom (BSIP Cloud) and OVH in France
- Spain’s Telinformatica
- DirectCall in Brazil
It’s clear that throughout our Update 7 - Alpha, Beta, Release 1 and 2 respectively, we’ve continued to add new providers. It’s testament - not only to an expanded list but also our commitment to keep adding to it. Watch this space as we continue to grow the list further over the coming months.
Better IP Phone Configuration and Support
Snom Phones with SBC Support: Another vendor has committed to integrating the 3CX SBC on their phones, The new D862 and D865 phones can now act as router phones.
Mass Provisioning of Phones: User and pin are no longer required. All you need to do is enter the MAC address of the phone in the Web Admin Console and then connect the phone within 14 days to automatically and securely provision the phone.
Manual IP Phone Configuration: If you have older phones that require manual configuration you can easily add from the interface. In this way you can configure the Auth ID, password and 3CX PBX FQDN/IP or SBC router IP via the web interface of the phone. Some popular phones here are:
- Avaya 9601, 9608G, 9611G, 9621G and 9641G
- Aastra 67i Series: 6730i, 6731i, 6739i, 6751i, 6753i, 6755i, 6757i
- Cisco SPA Series: 302, 508G, 525G/G2 and others
- Yealink T19P, T20P, T21P, T22P, T26P, T28P, T32G, T38G
How to Get Update 7
Users can access the update as follows:
- Windows and Linux Debian 10 users
- Log into your Management Console
- Update to "New 18.0 Update 7 Final"
- StartUP users
- You’re already running U7 Final!
- New users
Current NFRs, Trials and Commercial instances running on 3CX Hosted are updated.
Join Us at U7 Webinars
Register for our free 3CX webinars scheduled for early April across all regions to explore U7 features and improvements. Don’t miss out, places fill fast, reserve your spot now!
Tell Us What You Think
Tried and tested! We know you like our product as much as we do. We value your opinion. So let’s meet in the Forum. We’re looking forward to your feedback!
