DECT Headset recommendations
Alphabetic
3CX MVP
Hi guys
We've been using Yealink WH62 headsets, which have been great but we're finding they break very quickly and the headset ear cushion doesnt last.
Is there anything similar you lot are using that plugs in to the phone and PC and can be used for both?
The newer Yealink WH64 is a lot better than WH62. They learned a lot. Also you can order replacement ear cushions for both models.
Reactions: p_angel
that looks good, ill get myself one of them :D
Are Your WH62 always under warranty? because i did a RMA with one WH62 on which the arm broke at its base. I was not sure it will be accepted , but it was , thanks a lot Yealink !
I should normally receive a WH64 as brand new replacement on friday 24th
If you need to contact Yealink warranty service , here it is
yeah, its 4 days out of warranty xD
Funnily enough this headset, is a replacement for my previous headset that broke..
So either im the problem ¬_¬ or the headset is.
They're giving me credit for the headset but wanted something gorilla proof.
NetworkActive
