- Joined
- Jul 1, 2016
- Messages
- 6,619
- Reaction score
- 2,633
Im tested 3CX Live Chat config on a WP site with the plugin and find that the changes I make in 3CX are not instantly visible on the website - is this normal?
Hi, im not web dev by any means.Hello, it depends on which code snipper you are using.
If you use full snippet, it uses parameters defined inside snippet.
if you use short snippet -- it requests parameters from 3CX Instance.
Founded in 2005, when VoIP was an emerging technology, 3CX has gone on to establish itself as a global leader in business communications.
