Deleting CDR log files
NP164
I am just setting up CDR using the separate files for each call setting. I can not find any documenation on how 3CX manages these files internally. Will there be an issue with deleting the CDR log files manually from /var/lib/3cxpbx/Instance1/Data/Logs/CDRLogs? I was planning to automatically process the files and delete them once processed. Also does 3CX purge these files automatically based on age or directory size?
Hi @NP164
When Using Separate Files for each call:
The files are 100% managed by you, the system only generates them..
When Using Single File:
The system manages the file for you, according to the file size you specify in the options.
3K8iMGWviZ
