Department Call Restriction
SLRlooker
how is an easy way to limit calls between departments ? i basically want each to be their own island no inter department calls
The multitenant feature will treat them as separate companies…
This is the purspose of the Multi-Tenant solution where you can create seperate companies and not share information. Check the guideline here as well for further clarification.
Reactions: PaulC_3CX
Solution
amazingbv
