deskphone provisioning DHCP
dusfr02
Hi guys,
Im on a professional annual 18.0.1880 version, on the free year, deployed on a raspberry pi.
Provisioning for IOS and Windows PC are working great, but I would like to try to use a deskphone too.
I can have access to Cisco 7960 or Avaya J169, and I take a look on 3CX guide for those 2 models.
My PBX is deployed at home, and actually my TP-LINK AX3000 is doing the DHCP, but dont have feature to setup option 66 or 242.
What can I do ? Do I need to add DHCP on my raspberry pi to configure those DHCP options ?
Thanks so much !
Fred
Hi Fred,
DO NOT put DHCP on your Pi, it will bring your entire home network down to put it mildly :)
In addition, you cannot have a Pi act as a 3CX machine, and as a DHCP server, this will cause further problems.
A possible solution (which I would not really recommend) is to disable your TP LINK DHCP server, and setup another DHCP server on your network which does support options. This is not a clean solution and not worth it for those older models..
Those are Legacy/EOL phones so you probably won't find other methods to provision them.
Get something from our supported phones page which will not have such requirements:
https://www.3cx.com/sip-phones/
Hi Fred,
Thanks for your great answer.
Ok, I can see that Fanvil, Snom and Yealink models are easier for provisioning, with the plug and play on local lan.
If I can ask, I dont know those companies, but can you tell me which one could be a good pick for a basic functionality vs price ?
Really appreciated, you saved me a lot of trouble !
Fred
Having worked with all those brands I would say either one should serve you well.
Other forum members may also share their experiences too!
From the Yealink or Fanvil series I would recommend getting something from the models ending with a U (ie. Fanvil X3U or Yealink T43U) as these are more recent and should still receive updates for a while from the manufacturers. From Snom anything from D3xx and above should also keep you happy!
SupportRock
