Desktop app dropping when a Team's call comes in
mvandusen
Discovered this issue this morning when I was on a call via 3CX via desktop app and someone tried to call me on Teams, the 3CX call dropped. If using the web browser it does not appear to do it. I made sure "Allow call pop-up to steal focus on incoming calls" is unchecked.
Desktop app version 18.12.425 (when looking at settings in app it shows Desktop App (127.0.0.1))
3CX version 18.0 (Build 418)
Reactions: Lifesgood
Have the same issue when on a Teams call and 3CX comes in. So appears to be an issue on my PC as not able to duplicate on other PCs.
I also have this issue sporadically. Not able to identify the cause.
Are you using a Sennheiser headset?
No, Jabra. When i click to answer the call it beeps and drops the call.
Do you have integration with headset turned on? If so, which integration?
Which headset? Jabra 930 Pro?
I'm using a Sennheiser D 10. I do have Headset Integration enabled adn it's set to "Universal Headset Driver (WebHID - 3rd party supported)" and below that it shows Sennheiser D 10 for Lync connected.
Run a test and see if the issue still happens with Headset integration disabled.
Reactions: mvandusen
That seems to of fixed it!!! Thanks.
FWIW I ran into this the other day when I accidentally left my extension on available during a Teams call. Sennheiser/EPOS.
jb_erp
