Destination if no answer
Maurice Lefevere
Gold Partner
Is there a way to split-up the destination if no answer.
I know the destination if no answer is triggered by 2 different things
- Max callers in Queue is reached
- No available members
Now i have i customer who has set a max of callers in the Queue and sometimes all the members helping in that queue are temporarely away.
In scenario 1 were the max callers is reached it triggers the destination if no answer with a certain message.
In scenario 2 it also triggers but with that same message. The problem is that message is not rellevant for that moment.
When 1 is triggered the message is: It's verry busy right now. Please try again later.
When 2 is triggered i would like something: There are no available members at the moment. Please try again later.
Wouldn't it be more logical to make a seperate place to put an audio file under "Queue Preferences" so it triggers something different when the max queue size is reached?.
There is a similar scenario that is solved by a CFD app in front of the queue: the call comes to the CFD app, checks the queue for available agents (and / or maybe calls in the queue) and forwards the call or not. This way the queue does not become overcrowded. Maybe that is a solution.
Otherwise: use the CFD app when the queue overflows and change the greeting text there based on the availability of the agents.
There is a similar scenario that is solved by a CFD app in front of the queue: the call comes to the CFD app, checks the queue for available agents and forwards the call or not. This way the queue does not become overcrowded. Maybe that is a solution.
That sounds nice!. Do you perhaps have an example?, or were do i need to look at.
GetQueueStatus followed by a condition about GetQueueStatus.AvailableAgents or GetQueueStatus.CallsWaiting or both of them.
Also: look here for more control about 'availability' of agents.
add: look also at MAXCALLERSINQUEUE parameter of the DN of the queue, available at get / set dn property.
Reactions: Maurice Lefevere
Kayla Norris
