determine codec in use or a call and if transcoding is active
coreybrett81
Is there anyway to see what codec is being used on a particular call and whether transcoding is active?
The Activity Log should show that, after the fact, but , if you mean, in real time, while on a call, I'm not aware of a method to do that. Some sets do show an Icon to indicate an HD Codec is in use.
Unless you make changes, the Codecs used, for each call scenario, should remain the same.
Reactions: nub
abctel2
