Solved Dial Code Missing
Ron Gonzales
Hello, its not possible to use dial codes to force in/out straight off the bat. You will instead have to use the 3cx client to force phone system in/out and ensure user has the correct role set to do so. Alternatively, look at this https://www.3cx.com/docs/call-api-linux/ (self hosted required)
Reactions: Charles_3CX
We are not self hosted. But I havent heard or been able to search for the web client function and role. can you point me in the right direction on what role is needed and how the users can set the system into night mode.
Wow, that was super easy. THANK YOU
Glad to know this is solved. Note that this has also been clarified in this Forum.
ARKC
