- Joined
- May 15, 2019
- Messages
- 17
- Reaction score
- 0
I have a couple of questions, one is about license: My license is about to expire in 10 days but, I just download and installed the system within the las 45 days, is that common?
I am on v16 everything worked well, and none of this issues where present, I don't know if it is because the license is expiring but, everything stopped working and now this are the issues I am having. Appreciate any help of guidance.
Using a cp-9971 Phone System
Inbound Sip all active everything forwards to the right extension call work and outbound calls work well. I have the system append the (1) digit to the numbers dials for simplicity, if not the user has to dial using a (1)202-555-1212. This works well for us.
for some reason my inter-office dialing is no longer working, when I try to dial any extension or any number for a matter of fact and I either use the speaker or the handset, when I press the first digit it returns an error saying "you have dialed an invalid number" the only manner that I can dial the extension is by begin typing the number without lifting the handset or activating the speaker. Was I enter the number I can press call on the screen and it works, I can touch the speaker button and it works, I can lift the handset and it works.
The problem only happens when I first click the speaker/handset and get a dial tone, than I get the message, you have dialed the wrong number.
The behavior is the same whether I am dialing an internal number or outbound call. Its driving me nuts.... can anyone help.
Also, my Contact button was functioning and pulling up the Contacts, and it has stopped working, together with the voicemail button, voicemail I can still get by dialing *4, but the contacts do not pull up using the url.
