DID and wildcard
infosetsrl
Titanium Partner
Wildcard asterix not working at the end of the did number. For example +3912635* cannot be recognized. Faeature was avalailable in V18 and must be included also in the latest V20.oduce wildcard
Upvote 2
The * should ideally be at the beginning of the number, not the end.
The wild card is used to alleviate any discrepancies from your provider.
So if your DID is +3912635789 the PBX will route the DID if it EXACTLY this number.
The * is used if the provider is sending the number in as 3912635789 or 012635789. In these 2 cases it would route to the Default route.
So, *635789 would ignore the beginning of the number and route to the DID.
If it is "not working" in your case then that would mean the BEGIINING of the number is not matching most probably.
devo.it
