Different messages on v18 upgrades
Alphabetic
3CX MVP
Good morning
I did 2 upgrades to v18 last night but I received 2 different email messages - why is this?
could it have been the OS was already Debian 10?
Msg1
3CX was successfully updated.
Your installation at xxxx is now running the latest version and all 3CX Services are up and running.
We recommend your installation is always on the latest version for potential security fixes, new and improved features, as well as better compatibility with SIP Trunks and IP Phones.
Read more about the latest product releases here: https://www.3cx.com/blog/releases/
Msg2
Your 3CX Debian OS at xxxx was successfully updated to the latest version and all 3CX Services are up and running as normal.
We recommend your installation is always running the latest version. In addition to potential security fixes, updates include new or enhanced features and better compatibility with SIP Trunks and IP Phones. These will improve the stability of your system.
Check the full change log here: https://www.3cx.com/blog/change-log/phone-system-change-log/
Hi @kieferschild,
You're correct. If you do a regular update you'll receive Msg1. If you perform an OS update you'll receive Msg2.
WagnerFT
