Different Sip Trunk destination
abdallahessam
Dears ,
I have inbound calls from another issabel server connected with my 3cx server through a sip trunk how could I create 2 different destinations between 2 kinds of calls incoming with the same sip trunk
Add a DID number in inbound rules and route it where you want
Unfortunately, it didn't work with me , it always calls reaches to main DID
most probably your inboud rule is not followed due to wrong number format and then main trunk catch all
if you have for example number 0123456789 as DID try to create an inbound rule just starting with *456789 and route it
Try to see what happens in the logs and what is the number received by 3CX side
Reactions: YiannisH_3CX
awan05
