Digital receptionist options not selectable
grappa
We have two digital receptionist groups on our hosted system. We used to be able to select them and make changes. Now, the application doesn't give use the option to select or modify the digital receptionists. Would anyone know why?
TIA
Are they DTMF type or standard?
They're DTMF. "press 1 for x" etc.
Both standard and DTMF can do "press 1 for x"
Screenshot from v18 - the DTMF types can't be used in v20, you have to delete and recreate as standard.
From v20:
DTMF type IVR will probably come back in a future update, but for now you cannot modify them in the new admin.
Reactions: OlegR_3CX
So should we delete and recreate or wait ?
You won't be able to recreate so if you need to edit it, might wanna move it to a CFD instead.
  • Haha
Reactions: Merrick
That is not really acceptable. I need to make modifications to my IVR but unable to, and to suggest some odd work around is not going to happen.
Then you should rollback to v18.
  • Wow
Reactions: Merrick
The upgrades haven't been handled well IMO. It's amazing to me that this would be omitted
They can be recreated only as standard and not DTMF, standard works. CFDxDxD!
We had a similar discussion here, in case anyone will find it helpful.
costionofrei
